- 10:11 PM
- Dec 25, 2011
- White Cloud, MI
Once again I concur with Doug. I would replace the front clutch retainer bushing (on every narrow/early model retainer) and tighten the end play of the entire assembly. The factory realized and corrected the front clutch retainer bushing width, as it wasn't wide enough to properly support the load so less end play helps to keep the retainer from "cocking" on the stator support.
I have installed dozens of Transgo shift kits over the decades and they always performed as advertised. TG makes a "No Yo Yo" kit with a modified manual valve that allows the pump to fill the converter in "park" which speeds up initial engagement (due to converter drain back). Used quite a few B&M kits also with good results. I've been through at least half a dozen parts suppliers over time and always had good results too.
I put a TG shift kit in my 1994 V-10 3/4, 4x4 (ordered new) at 60,000 miles and it shifts as good now (133,000) as it did the day I installed it. Happy days!
