SUPERSTOCKRACER
Superstock, that's impressive! Do you have any idea what you picked up for HP when switching to the Indy intake?
You sure must have your car working well for those kinds of times. I'm running Calvert split mono leafs, cal tracs and QA1 shocks on the rear with 90/10's up front and light torsion bars. Any tips on shock settings? It will be the first time out so I'll be starting fresh. Your comment on intake puddling interests me too. I'm not sure how you were able to correct that. I've had a few blown burst valves early on. Touchy things..
Around 80 hp gain switching from OE Crossram to the indy crossram. I opted for the offset indy crossram which gives up a little power compared to the inline Indy crossram which I have on my 588CI engine.
I ran Cal tracs for years. Every car is different. If you're running double adjustables, that will help a lot over a single adjustable shock.
Who's block are you using?
