69'Net
Oi pressure question: I have a freshly built 440. After the engine is at operating temp, my oil pressure is around 19-21 psi in park idling at 1000 rpms. When in gear, foot on the brake it drops to around 13 psi, 600-650 rpm Is that too low?
Temp question: Also, I have a 180 thermostat in the car. The hottest i can get the car idling is 180 degrees. I'm in Texas, its around 75-80 degrees right now even in February. The temp goes down to about 135 cruising. Is there such a thing as too cool? I even took the fan shroud off. From reading things on here, it seems I have the opposite problem as everyone else.
-Note: I have all mechanical gauges.
