Pics of Hotchkis Front Sway Bar mounts
Zeppelin264
6:12 PM
San Diago
I'm looking for some pics of the Hotchkis front sway bar and how they attach to the K member. I know its a weld in deal, but I'm trying to determine if I even have the hotchkis bar. Right now it's bolt on sideways which doesn't make any sense unless you saw a picture. But it seems like it sticks out too far past the k member to even work. Anything will help!
Ok here are some pics. Maybe once the "brackets" are unbolted the sway bar will push inward a little more?
I dont have a pic handy but that doesnt appear to be Hotckis. I just intalled mine this weekend on a b body and the brackets and curvature in center of bar do not look correct.
I have a front bar and mounts on a car I just picked up that looks very similar to this. It doesn't look factory.. Which is fine, but I have no idea what it is.
Looks like looks like mine. I have a pst solid bar setup and it just bolts to a hole on the k frame lip. But the hoop should be up as it's there to go over the lower road support bracket to the grill...
Not sure if relevant, but a friend put a Hotchkiss on his 69 Sport Sat. The Hotchkis sticker was visible, but the bar was upside down and scraped driveway entries etc. With the sticker upside down, the bar was properly mounted.
i have a 69 charger with a hotchkiss bar no mods to put in its one of the prototype bars they made it works flawlessly !! it came with brackets
Dennis be sure that you reed the instructions on welding of those brackets. Mine will get welded on when the car is done and on the alignment rack at the race shop.
Will do. I have competent help too.
