Mike Gaines
- 12:07 PM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
I did NOT change my "out of the box" jetting on my Holley Sportsman 1050 Dominator. I runs so good I am not messing with the jetting.Congrats on a new best and what better place than that meet!Do you data log or read plugs? Mineshaft air can be alot of fun!!
Car runs consistent 10.60 in 2500' to 3000" adjusted altitude (which is typical in the summer time at my home track of Famoso CA which is at 678' real altitude).
It picks up a tenth in early March and November weather when the adj altitude is less than 1000'.
My research shows that if the car has the same jetting and runs quicker at lower adjusted altitude than it does at higher adjusted altitude then the jetting is a little "rich" at the higher altitude and then perfect at the lower adjusted altitude.
So...I leave the jetting the same when I race at the higher adjusted altitude ( I do not lean it out ) so it is a little "rich" at the higher adjusted altitude and that slows the car down from 10.50 to 10.60 which is right where I want it to run the 10.60 index in D/Gas.
Doesn't that make sense ?
