wagon rear tire fit
330gerry
New Member
3:09 AM
winnipeg
what is the largest race tire i can get on the the rear of a 63 belvedere wagon?
i am not sure if the wagons have as much room as the sedans.
what size ,offset and brand of wheels?
it has a 67 b body diff.
any thoughts or input on tire brand and compound .
car should run appprox 12.00
  • gerry
  • 63 bel wagon
  • 67 satellite
Depends on your housing dimensions, and back spacing.
not sure if you meant by differential being out of a 67 b bod is your housing dimensions. And for a car that runs 12.00 you won't need more than a 10.5 tire which should fit easily. Unless you want wider tires for the look.
There's a plethora of tire options out there, MT, Nitto, Hoosier, Toyo, BFG
From research I've done 65-67 are the same dimensions.
  • gerry
  • 63 bel wagon
  • 67 satellite
I have a 275x60x15 with a 15x8.5 with 3.75 BS
this has the stock 65 b body 8.75 diff and it is the crager ss 15x8 rear wheel with 28x10.5 M/T slick
