Malicious
Hi All,
Just rebuilt a used highway diff for my coronet, and put it in on the weekend. I took it for about a 150km round trip to a car show.
On first use it was noisy; some on accel, but mostly on deceleration. after a bit of driving it quietened down a lot but there is still some very slight noise on drive and almost a whine on deceleration.
I found that when assembled the pinion was tight and adjusting the preload spacer with shims really didn't make a difference until it slacked off enough to have side movement. SO I built it to the tightest tolerance before it got side movement, although it was still not as free spinning as the other one I recently rebuilt. assembled etc and threw it in.
Just wondering if people think this should clear up after a bit more bedding or if the used gears are on the way out? or have I screwed something?
One last thing, its an open center and I ran the SAE 90 - GL5 LSD gear oil, no additive. Could this be part of the issue?
Cheers
Cheers
