Carb set-up help
My friend sent me this as it is on the motor already. Something is missing here or just doesn't look right to me. Anyone?
It looks like your bracket only has one mounting hole in it. I would look for a bracket deigned for an aftermarket intake with two mounting holes.
Indeed.
The one I've installed (from Mancini) looks, compared to this one, as though it straddles the #7 intake runner.
This one looks set back.
Lionized, do you have a picture?
That's what was given. Should I change that and does anyone know where to get the correct one?
Lionized--it could very well work. Check the travel on lever at trans per FSM and adjust as necessary on the 2 lengths; upper rod and lower(vertical) rod.
Mine's working pretty good, oldbee.
I posted this photo as reference for rrTor-Red.
I need to look into this more. to make the K/D, throttle work in sync. It seems I need part of the one I have and incorporate part of what others has as well, possibly. I'm trying to reach the guy who built the tranny because the K/D came from a vendor where he ordered the rebuild kit from. Hard to see things when I'm not home right now.
