Any help would be greatly appreciated.
It's going to depend on which model car, since after looking again, that harness is for a four headlight car. Year looks about right, though. Also add, in case you don't know, the two white wire lead with a ring connection...is the headlight ground. There will be a spot on the backside of the radiator support, it gets fastened to.
Single brown wire...runs about halfway down the driver's side wheel well. It's the power supply for the washer pump, that mounts there.
