- 3:57 PM
- Mar 10, 2010
- Hanover, Pennslyvania
It looks like you're good down at the trans.
I've seen replaced cables that turned out to be too short, if it was replaced in the past.
You have to make sure of the lenth by removing the housing from the speedometer and see how much cable is showing. Has to be enough to engage into the speedometer head when assembled and all tightened up. With the cable removed from the speedometer, push the cable into the housing and try to turn it. You shouldn't be able to because it's engaged into the gear down at the tail shaft. Take notice to how much cable is showing. Do the math and make sure there is enough to engage the speedometer head properly. You can also pull the cable from the housing on this end, for a visual inspection. A prominent square shape on each end of the cable is important also.
The other thing to check for operation is to put a drill on the transmission end of the cable, with the cable hooked up to the speedometer. Turning the drill in one direction will be like running the car in reverse and you won't get any reading. The other direction will show needle movement. I don't remember which direction on these anymore. Something tells me counterclockwise. You have a 50/50 chance at getting it right!
No results on any of these checks will be a problem with the speedometer itself.
