Did I hear the seller correctly that disc brakes was $3700?
The other question is was part of that total for installation....Sometime shops will add a % to the cost of the parts if everything is done through them, then labor cost can be crazy....Or he just threw a wild number out there...Yea, seems pretty pricey but hey it was his $ not mine, well I guess it is now, LOL!
In the end you have great stopping power now!No idea but there's always the piss off factor that could have been added to the final price. Either way its water over the dam now.
Guy did a nice job, better than the guy i used for sure... Love the owners laugh at the end of everything he says!
Did it really have 40 # of oil pressure at warm idle?
Also, do not forget idle rpm's....A higher than normal idle will raise the pressure..The grade of oil as stated...Even the type of pump can be an issue....or a cheap gauge...I'll have to go back & watch the video. God only knows what type of oil is in the engine but I'll be putting fresh oil in. I've heard that higher zinc oils are best to use.
Do you think Lucas ZDDP is good? This is what I used on my last oil change.You need zinc in the oil for the cam & lifters.
I hope it makes it....where are the tie down points?
Secured to what though?
