- 10:15 PM
- Jul 17, 2008
- South Jersey USA
it should be at the shop of YOUR choice...... and they work for YOU, not the ins co.
14g's. lots of cab work.
I bet that cab corner is less than 400 bucks, and about 10 hours labor....... I'd say it occupies only about 1200 dollars of the repair including paint and minor BS
plus a new bed and 2 new doors plus labor and painting...
they aint shelling out for a complete bed, or that front door....
It kinda adds that "coke bottle" look like the 60s and 70s Mopars.The complete door is toast as it's pulled out at the top. The pillar portion has me concerned also. Oh well, it's off to the estimator tomorrow.
what is the labor rate for collision shops in your area? it about 48/hour here.....the insurance companies do their best to steer all the work to their "preferred" shops...... makes it almost impossible for small shops to compete...
48/hr are you sure ?? I'll ship out my next paint job .. we're double that here
RC....are You in the shop of Your Choice?The front door only has a 3" crease, so that can be fixed, but I wouldn't be surprised if the quarter panel on the bed has to be replace.
Here in Cali, flat rates are highest in Country & Nor Cal higher than So Cal. Hard to make an accu judgement off a couple pix. Plus i think that with that color, if bedside is replaced, a blend in base color & overall re-clear will have to be done on tailgate & ditto on front right fender,(butt match no good)effectively a complete repaint on right side of truck. Out here, that alone would put a healthy tally on the sheet.oh, I'm sure..... as of 2 years ago anyway...... I doubt much has changed..... guys need to beat the clock on a regular basis, and the shop needs to make a decent mark up on parts just to survive....
a small shop with 1 booth and 3 or 4 employees simply can't compete with the maaco's, collisionmax's, and dealership shops
The rocker rail is most likely a replacement too...though it doesnt look it, the center pillar/door post may have gotten a push too.
Right On! It's always the Customer's choice by Law, but as eldubb said, lnsurance cos. will do their best to coersce or even trick people into their choice of shop.Yes I am.![]()
Out here, supplements are not so easy, insurance cos fight religiously for original sheet, so even with light jobs, shops will not give an overall estimate until a tear down is paid for.......only a rough GUESStimate until tear down.yup, you don't really know until you get into it....... the adjuster will only write what he can visually see....... supplements are easy and usually only require pictures of labor and old parts; and receipts for new parts.......
a good manager will make sure it's worse than it actually is......![]()
Yeah, so most shops wont make a move until the insurance adjuster comes out & writes his own sheet....so to keep himself from getting in a bind, 1st trip out is to write up a tear down sheet, then come back & write complete sheet after tear down.....then is when shop sheet is compared to insurance sheet & the haggling begins.wow, really? that original sheet is toilet paper in these parts
