jimm69
I have a 69 RR that I just finished last summer. While over the winter, I developed an issue with my starter. Sometimes you will go to crank the engine and you will just get a clicking noise from either the starter or the relay. cant tell which. Sometimes it will just crank right over with no issues. Sometimes it will start cranking and the best way i can describe the sound is a grinding sound like turning the key too soon after letting off the key and not letting the starter wind down. It is like it is losing power in the middle of a cranking session and starting right back up and grinding because it started cranking before starter winding down. I pulled the battery out and had it tested and it tests good. Took starter out and had it tested and it tested good.
Relay is 6 months old. All cables and under hood wiring is 6 months old. I have double checked that my connections are all clean and tight. Does anyone have any suggestions for me to try?
thanks.
Jim
thanks.
Jim
