superbeedave
Hi all,
I have gear oil leaking out of my right rear axle and it appears that maybe i need to pull the axle and replace something! I have never screwed with rear ends before so I am asking for some guidance at doing this. Can i just remove the axle or do I have to pull out the pumpkin first? This is on my 69 Superbee and it is not the original rearend and it is an open with 3.23's. And I am pretty sure it has no sure grip in it either. I did notice last night that I was finally able to put a dial indicator to check my end play and it was up to .05 which the book calls for .008-.018. I was wondering if that is why it started leaking? So i went ahead and pull the nut and tightened up the adjusters to where I now have .008 end play. I know I am reaching but before i pull the axle out I am going to fill it back up with 90w oil and see if it still leaks. Any help or a great video on how to do this would be very much appreciated. Thanks, Dave
