Pulling center link off
fwi
12:51 AM
BHC Arizona
Any advice on whether to use the pickle fork or C clamp type puller?
Need to get it out of the way to install passenger side headers.
I just replaced my inner & outer tie rods and idler arm last night. Little tension with a bar and a good smack with the hammer. I did need to air chisel the idler off the K frame though. The rest came off very easily.
I learned this after buying a 4 lb sledge. This makes a huge difference. I have beat the snot out of a ball joint with a 16 oz eastwing.. NO GO. Then I bought the 4 pound eastwing and learned the lesson that bigger is better in this case.
Correct advice on the hammer.
Never bring a knife to a gunfight
Went to Harbor Freight and bought the short handle 4 lbs sledge......worked perfect. Now I have to saw off 1/4" of studs to squeeze header onto #2 hole..
Update......trimmed both #2 header studs, disconnected center link, removed valve cover and.......it worked, pax side header is bolted in, tomorrow I install the driver side.....which I have already installed before, other than having to trim the second header bolt....:thumbsup:
Replace the crap rubber boots, with urethane aftermarket boots.
Well the driver side headers didn't fit as well as they should have....that big starter is in the way, ordered a mini and hope it works.
i hope it works out for ya
what kind of headers you intalling?
im looking at installing schumacher tri's on my 66 coronet, 440cu, 727, with power steering.
watermelon
watermelon
They are identical to Hedmans 78030 but made by Chrysler.
