66 Satellite Hemi Identification
G.V.Charger
10:55 PM
Grand Valley On.
New to this site, have an opportunity to view a 66 Satellite hemi convertible this coming week end. The owner is an older gentleman, that no longer has time or energy. Question is, is the vin numbers the same as 66-67 Charger vins, H code for 66 and J code for 67. And is there anything to look for on the fender tag, if it still exists. Car is an automatic, 8 3/4 rear I would assume, and the car is triple black.
Thanks in advance.
Not sure about the numbers but from memory the 66 Hemi cars used a unique mounting plate on the driver side fender well under the hood for mounting the starter relay, etc. I think this went away in 67.
This might help on the numbers.
http://www.lhmopars.com/vin66-74.htm
Good luck - one of my all time favorites.
Mint
Thank you
Yes, the numbers are the same on other models, H for 66 and J for 67.
That is correct. It would also have the boxed in reinforcements for the front spring perches & skid plate on the K-frame
6-Plymouth-Belvedere-II-Convertible-426-Street-Hemi-Engine-Citron-Gold-Poly-_2005-CEMA_-DSCN5973.jpg
Also, will have the starter relay bracket on the driver inner fender in pics above
If it doesn't have the fender tag and so number can't be verified I feel it needs further documentation to bring top dollar.
Would be interested to see pictures. If it has a fender tag on the radiator support under the anti-freeze there are numbers that match fender tag. That is if he'll let you remove sticker, if it a real nice you may not want to remove it survivor? Under back seat build sheet I found a second under the carpet driver's seat.
One last Hemi trademark...The Engine Wiring harness that runs along the passenger side valve cover, has a male/female modular plug in the harness just below #6 plug wire to ease valve cover removal. That is unique to Hemi's.
Man I LOVE your Drop Top!
Under the AB on the fender tag will be 73 for Hemi.
Wouldn't it have the torque boxes even if it wasn't a Hemi car because it's a drop top? Skid plate would be Hemi only, though.
