Canyon707
I dont have any problem sharing the build I have it posted here somewhere but, who knows where it is. So here it is again.
511"
400 factory block
Main girdle
ARP main studs
Eagle 4.25" stroker crank
Eagle Rods(new bolts)
Ross Pistons
(The above rotating assembly was in a C/Gas car previously with 211 passes on it. All was checked and reconditioned, new rod bolts
installed. The block was not the same block that was used there. It is a fresh 400 block that was line honed, bored and torque plate
honed, rotating assembly was then all balanced and NEW main girdle was installed.)
Clearances are .0025-.0030/.0030
Clevite bearings and Total Seal rings
All balanced of course
Indy Maxx oil pump
Compression ratio is a bit over 12-1
Comp Roller .730/.730 lift 284/288 @ .050
Comp lifters(new)
KB Gear Drive
Indy 440-1 heads with full CNC port flow 390@.800(new valves and guide liners installed and honed)
1.6 ratio T&D rockers
Pac Springs, retainers, locks and caps
New 2.25/1.88 Manley Valves (11850-8/11813-8)
ARP Head studs
Trick Flow pushrods
Fel Pro Head gasket
Indy 400-14-3 Intake, Dominator flange
511"
400 factory block
Main girdle
ARP main studs
Ross Pistons
Indy Maxx oil pump
Comp lifters(new)
KB Gear Drive
ARP Head studs
Trick Flow pushrods
Fel Pro Head gasket
