65-440
- 10:35 AM
- Dec 2, 2009
- virginia beach, va
I knew it was only a matter of time before I needed to address my radiator, the factory 1968 small block 22" radiator isn't up to par with my .030 over 383..... I've been looking at the ecp 2 1"tube units. I'm torn between the 22" or the 26" ... I do have future plans for a/c install. The front support opening is only 22.5"wide, with a 26" radiator that would leave 1.25" on each side of the radiator covered. Would that honestly make that big of a difference ? I do Have a factory 26" shroud and will be running a 7 blade fan with HD clutch. The 22" would be a direct drop in but I don't have a shroud and would that be enough for a warmed up big block with a/c ??
