plymouthman72
Yes, very nice work, how did you go about cleaning up your lines? Something I will have to be doing shortly.
I used 4'' wire wheels designed for a grinder as well as polycarbide wheels for the same (Both at Harbor Freight). I was very careful to not apply any real pressure so I didn't damage the lines. The wire wheel worked really well with the brake hose because it has the spring type protector going all the way around it. After I was done, I lightly sanded them with some 500 grit sand paper, then clear coated them. I am sure there is probably a much more efficient way to do it but it worked well enough for me.
No doubt the quality and craftsmanship will be top notch and they will meet your deadline and goals
