- 3:00 AM
- May 14, 2011
- On the Ridge, TN
Ah, I'll go have a look in a bit thanks!Can you see it behind the linkage on the carbs main body?
There is a "W" on the left and
Magnetti Morelli over each other that is more centered.
EDIT: Went out and checked. The new 1805 Thunder AVS is just like yours.
The older 1407 I'm trying to rebuild right now only has the "W" and instead of Magnetti it says WEBER in big block letters.
