oldbee
You should have a 3/8" fitting combat out the carb,probably coming out of the rear. It pulls vacuum from both sides of carb & is the best place. Leave that 3/16-1/4" fitting alone for the vac. advance.
Nope. Only vacuum on the carb is the little one.You should have a 3/8" fitting combat out the carb,probably coming out of the rear. It pulls vacuum from both sides of carb & is the best place. Leave that 3/16-1/4" fitting alone for the vac. advance.
coloradodave - My son did some research last night and found out the carb we were trying to use is off a 1966-68 Corvette L88.
Car was points but engine is from 1977 and had OEM electronic ignition
Swapped out the distributor for a replacement new distributor which is standard hall effect vacuum advance style. New rotor, cap, and distributor
New accel 8140 coil after original coil and coil off another engine and a new oem style coil failed to cure sputter
new ignition control module was purchased and engine failed to start. Replaced with control module out of a 72 Charger and runs now
New 8mm plug wires
New spark plugs gapped .35
You don't say a thing about what year your car is,
Very first post - "I have a 1977 440 Motorhome engine in a 1969 Charger"
which Regulator you used
Cheap O'Reilly transistor regulator (twice, one was bad), used regulator off a 1972 Charger, and the original regulator out of the 77 motorhome. Sorry, do not have the part numbers. Tell me which one I should be using and I will go buy that. This morning the voltmeter I added over the weekend said 14.4 volts at 1500 rpm. Also kept the motorhome two wire alternator.
and a few others.
Sorry, not sure what this refers to
Read this then tell us what's wrong!
No clue
Early Charging System modified for use with a 70 style VR
There are a number of reasons one might want to upgrade a pre-1970 system to a transistorized voltage regulator. The list of reason include
- Chrysler recommends you switch to a transistorized VR if you upgrade to an electronic ignition from a points style ignition.
DONE
- If you have to buy a new voltage regulator, the difference in cost is only about $5-10 more for the transistorized unit. Not to mention, the quality of replacement early style VR's is spotty.
DONEBelow is a diagram describing how to install a 70 and later Voltage Regulator on a sixties mopar.
- The transistorized VR will have a longer life.
OK, sold me 2 months ago
http://www.imperialclub.com/Repair/Electrical/charging.htm
DONE
