steve from staten island
- 11:18 PM
- Sep 24, 2012
- staten island,ny
I may have a issue and I'm trying to stay calm. I cant get the car to run right. I have carb issues and I'm waiting for a new choke as the old one hangs up. Ive tried adjusting the carb after its warm but it still wont idle good. My question is first about timing. I trued timing it to zero on the tab on timing case cover with vacuum advance plugged. It wont run right. then when i connect vacuum advance it advances so much that idle screw wont slow it down. So now i dont know were timing is as I've been doing it by ear
My question is i know to far advanced will make it knock under load but now when i rev it a little i hear what i think is a rod knock. Ive heard engine knocks before and this sounds the same. Granted my hearing sucks but its there. Don't hear it at idle and at steady rev i dont know, but when i goose it i hear it knock and dam it sounds like a rod.
The background is there is no millage on this motor and maybe only a few hours running time. The heads were done by a good auto machine shop. I bought a short block from a guy that was 30 over and crank was cut 10 thousands. Had new pistons, TRW replacement rods. The motor was dirty from laying for years, i took it apart cleaned everything and reassembled. it spun nice and the clearances were within tolerance. However I'm no engine builder. I was on more of a budget back then and i admit to making many mistakes with this car. Im really needing to hear what some of your opinions are about the timing versus the knock i hear.....Thanks
