Wietse
Today i will give it another attempt.
I know which Ridgid pipe wrench you are on about and i wish i had one. (at work is also my best friend as Chief Mechanic offshore)
I'll get some other supply's from the hardware store today anyway and will check if i can find one.
Try and see if i can get a Torx socket in there that sits a bit stiff, and with a pipe wrench on it as well and pull as f*ck.
I will lift the distributor as well to see what is the damage, hope the camshaft is ok.
Yesterday the Vice grips slipped over and could not get a new tight grip again due the lack of space.
I gave it some thought yesterday evening but converting to a electric pump is not as simple as i was expecting.
And to convert to that it should be a good job with proper installation and not a temporary setup.
All this started with doing a re-adjustment on my carb is it was running very rich at idle and didn't run as smooth as i wanted.
At higher rpm the engine goes nose done and dies at me, after a little light throttling it picks up again.
In my other thread regarding this issue we came to the conclusion of fuel starvation, found a blocked filter but still happened so suspected the fuel pump.
Now it looks like the fuel pump was ok, just not being operated properly anymore causing a lack of fuel.
The old pump is a Carter M6903 and i bought the exact same one again.
