Modern Bullitt build
I took a little break from the block sanding and bodywork and started making the aluminum front bumper brackets. Made a paper template of the driver side mounts and was very surprised when I flip the template inside out and it fit perfectly on the passenger side mounts. Need to do some welding and bend up the other 3 mounts.
Pat
The right side mounts are bent, just need to be welded and then the welds ground down. I will test fit when the bumpers return from Paul's chrome before I paint the mounts, I'm sure they will need a little tweaking to fit.
Pat
Finished welding up the right side bumper mounts and ground down all the welds. When painted black I think it would hard to tell that they're not original.
Pat
What make and model of mig are you using for all your sheet metal welding? Also, what size wire - .023 or .030 ??
You have been an inspiration to me. My car sat for 30 years with only plans - no action. Seeing your work has given me the incentive to get at it. I turn 65 in 3 weeks ... hopefully I still have a drivers license when its done !! I've been diligent in refurbing everything as I removed it from the car so hopefully reassembly will go quickly and smoothly.
I have a Miller 140 mig welder and use .030 wire. It has an auto mode but I alway use the manual settings.
Thank you for your comments and good luck with your project!
Pat
Sorry. I gots to do this. Those my lil blocking buddy are the famous last words. The song of my people.
