- 6:36 PM
- May 14, 2011
- On the Ridge, TN
Didn't know what forum to post this under so move it if you need to, mods...
Anyways, first the pics (car is a '68 GTX):
Yep, you're seeing this correctly - this fender has no evidence of ever having the normal larger antenna hole in the fender where all the others are.
Instead, it has this smaller (1/2") hole stamped (not drilled - "punched" might be the better description) out of the very corner of the fender, right in front of the door (and just forward of the hinge).
The car is a factory radio car and I've just picked up a radio for it. Now I have to figure out what to do with an antenna.
Does anyone know of a compact type antenna that only requires a half inch hole? What size hole does the original antenna actually need?
