Polara electrical
dukeboy_318
4:37 PM
usa
my 64 polara was converted to electronic ignition years ago by the previous owner. shortly after he did, it caught fire and melted the main harness. So I plan on replacing the entire chassis wiring harness and converting back to points. However, I want to see if i can make the poly 318 run. I have the poly points dizzy coming and a coil. To just start the car, and bypassing the main harness, all I should need to hook to a battery is the starter, and coil right?
Dukeboy ur right but not for very long runtime. Ballast drops 12v for coil&points so they don't burn up. I'd say nothing more than to make sure engine starts&runs.
well
There is more to it than that...
You need the Ballast resistor correct?
I can wire one in if need be,
thats all i want it for, just to see if she'll run.
