Let me know next time your this way!
Be sure to test the function of our toggles in the switch panel before installing it....The repo's can be tight to switch and require some fitment....So I got this company name for rivets to replace my rocker buttons and thumbwheel on instrument panel. Hansonrivet.com I'll let you know what I find out. I think they were semi tubular rivets for the rockers & solid for the thumb wheel. If anyone else is looking for these let me know. I got the chrome pieces from Mega Parts.
Hard to see on my phone but appears about a 1/2" higher?View attachment 513436 View attachment 513440 Also notice my air cleaner sits higher,
I didn't look that close but Tommy did all of them....if that's what he uses that is what they have. If you send him all your switches, send your panel as well. He will test for everything....I looked at that but, the lip of the base I think is still to tall. I put the Schumacher motor mounts in and they looked tall at the time. I may go back and put solid motor mounts back in to lower it a bit. I'm sure the trick flow alum heads and phenolic spacers make for at least .5 of an inch.
It doesn't look like the aftermarket hood I have was made to seal to the hood. I'm sure I can make it work, will just take some more time. Good thing I didn't try to put the stock hood on!
This will have to wait till later as right now I'm concentrating on getting the dash and wiring done so I take it to the interior guy.
Justin did your switches have roll pins or rivets on the rocker pivot? not sure I can tell from the picture. Tommy told me he prefers roll pins, as rivets can be to tight or damage the chrome rockers.
Will do, I do not have one at the current moment but I do see them on ebay a lot...So if you happen across a on off plate ley me know! I will be on the hunt for one.
