I was bored so i pulled the valve covers and lashed the valves.  The heads seem to be getting plenty of oil, no other issues.  There were a few valves that needed a tweek but nothing substantial.  While I had the valve covers off I checked rocker shaft caps torque and inspected the keepers.  Again, everything is good. I did have to tighten the header bolts.
On the valve covers, especially the aluminum ones, I apply the gasket to the cover side via Permatex High Tack. Keeps it from squishing out and makes it easy to remove the covers to set lash.
Done.
I have some Gibbs Driven oil on the way (sale at Summit) along with a filter so the oil is going to be changed this Tuesday.
Done.
