moparnation74
You have HP manifolds...ZERO effect...they are cast iron headers...I agree with you regarding the timing and carb focus. I was wondering what the effect of timing has on engine heat and what other factors come into play, such as cam specs, manifolds, etc. I can only imagine how much heat is trapped under the hood in 90F+ weather while idle. This is likely what is causing the sputtering, etc. This is the only time it has happened since putting a spacer and sock on it. The temperature has been fairly mild this summer however.
Cam affects timing.....
Yes, you ran better on a cool day but I think that problem was there then and benefited from the outside temps...
