Sticky Stuff on the Nuts
Jimmy Fallon's got sticky balls.
And he did not get to close to the honey and still has sticky nuts?
Nothing like window glazing. I have removed some old glazings that could pass for concrete in hardness.
Dum Dum sealer......like the **** some fools use to set plexiglass aircraft windows before bucking the rivets,,,then when it gets hot the **** swells out of the seams. Just use some urethane windshield sealant or silicone caulk,, hell You could even use latex window caulk if You don't want it to harden.
Yep, Dum Dum, 3M strips like H2E said. The same stuff is on the tail panel and side marker speed nuts. Getting a box of dum dum would be overkill, but you should use something to seal the speed nut on the rivet.
OK, looks like I'll be filling in for Mr. Cranium on this one...
Looks like he's slipping a little.
Seals gaps and holes against dust, moisture and drafts. Do think waters going to be a problem when used properly. We are not planing on submerging it for extended periods of time now are we.
