Wietse
Gents,
Today after some heavy throttling on the road i noticed there was some oil drops on the passenger side crankcase breather dripping on the header causing a smell. (reason for opening the hood and check where the smell came from)
Anyway, this is the current setup:
Passenger side valve cover has a breather only. (no hose connection or anything)
Driver side has a pcv installed (recently) and a oil fill cap.
Thinking i was doing the right thing when installing the pcv was to connect the pcv hose on the air filter base plate.
Now after some searching on the forum here i came to know that this connection on the air filter can be used to connect a hose that leads to the breather. (and not the pcv)
This way there is filtered air entering the crank case.
The other thing i found was that the pcv needs to be connected to a vacuum port on the carburetor so the vacuum is at best to pull the air through the crankcase.
With this setup it makes me wonder, i would class the air coming from the crankcase into the intake manifold as "false" air as it did not come through the carb and it's throttle plates.
That makes me doubt if i am correct in saying i need to connect the pcv hose to the carburetor manifold vacuum port.
I have only one 3/8" vacuum port on the back of my Holley carb and there is a hose for the brake booster installed.
Can i Tee in the hose for the pcv valve here as well, as close to the carb as possible or does this fill up my brake booster with oil and fumes?
Or better to connect to a smaller 1/4" connection up front of the carb?
Obviously i have a poor crankcase ventilation and i need to get it up to specs to prevent oil being spewed out of the breather.
I've read an article which was posted in another thread regarding the importance of the CCV system but it does not clearly tell me where to hook it up on a carbureted engine.
Can someone please advice me what the best way is to set this up?
