67 RT spring relocation and mini tub
What would be the easiest way to move the diff back a little?
If you're using the boxes provided with a spring relocation kit, I'd just set them back an inch from where the stock wheelbase would land and weld the rear hanger tube through the frame with the same 1" offset. I didn't give it a real good look because my job was done before I thought of it, but I don't see why that wouldn't work. You'd need a longer driveshaft however.
29" Goodyear, and yes......front corner moved. 30's were very tight.
