If you look at the traction and treadwear specs the Cooper is a better tire than the T/A. Even the Master Craft Avenger RWL has better numbers.
FYI the Radial T/A line is now made by Coker Tire, and not Goodrich.
T/As were all the rage back in the 80's as stated earlier.
First it was goodyear eagles, but they were super premium priced.
I personally didn't care for eagles (and I worked at a goodyear for a while), I found the GT to have an odd compound that flaked off when hot, and wore out super fast and ST to be a much inferior tire to my favorite at the time Uniroyal Tiger Paw.
Try Hankook for RWL 16"
You can find the above mentioned brands in less then 1 min on ebay in all sorts of 14 and 15 inch sizes in RWL.
...and I also have a set of 14's with discolored lettering.
At first I thought it was because the blue protective wash stayed on too long, as the 15's I bought at the same time didn't have the issue, and I mounted them several months earlier.
Has anyone tried Westley's Bleach White on them? That was going to be my next move.
