andyf
Pump gas engine running unleaded premium. Intake was ported by Wilson Manifolds, solid roller cam. Should run 9's if you can get it hooked up: http://www.hotrod.com/articles/dyno-tested-vacuum-pump-help-engine-make-power/
Keep the 383 on a pallet in the corner of your garage Incase you decide to sell the car. Build a 440 or 400wicked build! speaking of low decks, I have a question. Is it worth building a 383 stroker (431)? or should I just ditch the block and go 400 or even more, a 440? original block for the car so I thought it may be cool to keep the 383. what are your thoughts?
THANK YOU ANDYPump gas engine running unleaded premium. Intake was ported by Wilson Manifolds, solid roller cam. Should run 9's if you can get it hooked up: http://www.hotrod.com/articles/dyno-tested-vacuum-pump-help-engine-make-power/
Cheaper to build what you already have.
Almost cheaper to buy a rotating assembly from 440 source vs getting your crank crack checked/turned/ balanced, buying rod bolts, crack checking/resizing rods, buying Pistons, rings, and bearings.
For street engines
383-431 is a good combo. Some say the smaller bore schrouds the valves. Haven't noticed this.
400-451 is a great set up
400-470 may need aftermarket heads to work right
440 is great
THANK YOU ANDY![]()
Appreciate ur expertise !!Pump gas engine running unleaded premium. Intake was ported by Wilson Manifolds, solid roller cam. Should run 9's if you can get it hooked up: http://www.hotrod.com/articles/dyno-tested-vacuum-pump-help-engine-make-power/
