Show me your 15" tires
225/70/15 on a 7 in rim on ft.
255/70/15 on a 8 in rim on bk.
I like the taller 70 series tires because it fills up the wheel well better.
295-50-15's on the rear of my Charger. I went with 295's because i wanted more of a stock ride height & didn't want the jacked up look in the rear.
I have a stock 68 Charger and thinking about 295/50/15x10 on the rear but was unsure if they would fit w/o scrubbing the fender wheel...do your tires scrub any?
I just put 295/50 r15 on a 15x10 rim on the rear of my 68 charger and had no issues
Do you have a 68 Charger? I have a 68 8 3/4 rearend with air shocks that’s coming off to be replaced by Bilstein shocks. I’ve been going back n forth from 275 and 295, don’t want clearance issues. Currently I’m running 265/50 but want to go bigger and wider.
69 Coronet R/T. Pleased with the Bilsteins. Got them from Hotchkis, Mopar tuned. Now available from PST or vendors here.
For a 68 Charger well it be necessary to change the original leaf springs on top of getting the Bilstein shocks or can I get the shocks without having to worry if the rear will scrub?
255/60 in 15x7, 3.75 BS all 4 corners. To me, the best “stock look alike” on non stock size without overthink the fitment issue. Simply “plug and play”
First Dunlops, Firehawks later but both brands on same size.
I got a diff tire for the spare keeping same diameter but smaller width ( having SG is important) to make it handly and smaller on trunk, but can’t recall which one it is. It is white line thought
im running 235/60r15 on the front with a 15X7 rim. I think the backspace is 4.25 but I could be wrong. I will have to go double check, but I ordered them from wheel vintiques and told them I wanted a 15X7 rim with whatever the standard backspace was.
