dvw
Nearly 500 wheel stands and counting. Boxed the bottom also.Wow thats a clean k member dont look like its weakened it at all
Obviously your running a front motor plate are you running a rear plate also DougNearly 500 wheel stands and counting. Boxed the bottom also.
Front plate only. Limiters at the trans controlling fore/aft movement.Obviously your running a front motor plate are you running a rear plate also Doug
Going to pull the k member out of my car this weekend and cut it down thanks for the info Doug
The "K" does not need to be removed ,but can make for a more pretty modification.I followed DVWs idea of cutting the "K" and did it in the car.There was not that much left of the motor mount/steering box mount so these brackets came into use.Going to pull the k member out of my car this weekend and cut it down thanks for the info Doug
That’s awesomeThe "K" does not need to be removed ,but can make for a more pretty modification.I followed DVWs idea of cutting the "K" and did it in the car.There was not that much left of the motor mount/steering box mount so these brackets came into use.
View attachment 554960 View attachment 554961 View attachment 554962 View attachment 554963 View attachment 554964 View attachment 554965 View attachment 554966
That’s nice work what it set you back ?I was going to use the QA1 front K member for my A-body big block drag car, but when I called them to see if it was available without motor mounts, because I'm using an engine plate. I was told No, and when I asked if I could simply cut the mounts off, they told me the structure would be compromised. So I told them no thanks. After a little searching I found a guy on for A-bodies only-(member name-junior636) who fabricates k-members for A-bodies in different configurations, depending on your needs.
I don't know if he has a jig to make it for a B-body, but you can check with him, you never know. He does exceptional work and is a good guy to deal with.
This is the one he just did for my 71 Dart.
I will be installing this k-member with all QA1 components and wilwood brakes.
View attachment 554984 View attachment 554985
I have been watching this thread closely. I have asked you about front suspension advice, and as always you gave generous help. Thanks for these details.My last 2 RR's had QA1 stuff
{or the org. Capps Automotive, QA1 bought them out}
this one it's QA1 k-member
& QA1 LCA's with the sway bar mounts added
SPC dbl adjustable UCA's with poly bushings & ball-joints
QA1 dynamic adj. strut-rods
Uni-steer rack & pinion {I wouldn't recommend}
Summit racing {Hellwig} Sway bars front 1-3/8" & 1" rear
{I want it to handle when I'm not going in a straight line will disconnect the links when at the drags}
SSBC force 10 disc's
New Moog lower ball-joints
probably stay with the org. 383 T-Bars,
my last car I had 1" MP's they were too stiff for my liking,
but great for handling,
with the bigger frt sway bar I don't think I need the 1" TB
$540
$450
$200
$240 each=$480
$1000
$600 front + $450 rears = $1050
View attachment 555121 stock photo
The formula has worked very well fo the past 2 cars,
the 3rd will be just as good IMO & I have the parts already...
One question Budnicks, is there another rack and pinion setup that you would use? I would REALLY like a manual rack and pinion, but I would consider power if I "had" too.
Thanks. Almost too much to read, much less DO...![]()
I have in my mind that R&P is a "better" way to steer from an engineering/design perspective. What I am hoping for is a better "feel" to my front suspension, and better function. AFAIK, I may find that just having all new parts may do the job.
