Wire Harness choices
snakeoil24
6:44 PM
New Jersey The State of Tax Theives
I am the point of either building my own harness or buying. Since I have a 67 coronet rt Im updating the charging too solid state regulator, all new electrical Auto meter gauges entire new insert for gauges. Electric fuel pump, msd 7 al gold box, updated sanden compressor a/c cause i hate hot cars at my age. Trunk mounted duel battery and i am looking for input..
How is the rest of the wires? If your gunna update,do it ALL and not a little of this system and a little of that.There are several providers of complete kits down to DIY kits.Just do it right and be DONE!
They are generic kits that you determine what relay turns what on.The kit just makes it simpler supplying the majority of connectors,relays,switches colored wire.
I am currently installing a Ron Francis 7x24 kit in my 67 Coronet. Its going quite well but if I had it to do over again I would have gone with the Ron Francis express kit simply because you pull the wires to the fuse box making for a cleaner install and you only install the circuits you need. If you opt to go that route call them and they will build it to suit your situation. I bought mine via a third party so there are some connectors I do not need since I have an MSD box and not a Mopar ignition system. The overall quality is great and unlike painless they dont make you pay a premium for being a Mopar guy. The painless kits are way overpriced. They sell you a $300 chevy kit with some different connectors and charge you $650.
Does the kit go from the front lights to the tail lights?? I need to do under the dash and would like to make the directionals & tail lights in LED.
Yes its a complete kit from headlights to tail lights. I am still in process of wiring the lights but the directions state to use a LED specific flasher if you go with LED,s. Once this cold snap moves out I will get back at it. I should be done in the next 2 weeks.
Ron Francis will upgrade the harness if you are installing the battery in the trunk and/or using a higher amp alternator. No charge! Call them direct.
