vacuum advance canister source for b engines
Buckeye Bird
11:36 PM
Ohio
Cannot find any vendors that supply new OEM point distributor vac. cans for B or RB blocks. Any suggestions? Thanks in advance!
I know two guys that do vacuum advances....One guy is in Forney, Texas....I can't locate his info at the moment.
The second is.. http://crossramconnection.com/distrest.html
Owners name is Brian and you will have to call but he does have correct vacuum advances
I bought my B engine reman dist with adjustable vac advance from Orileys. I would figure they could get the advance can, them or napa.
Just about forgot but there is a member HALIFAXSHOPS that sells rebuilt distributors in the for sale section on here.
You may be able to buy one from him.
Good advice.
Ask me how I know lol.....
Some have tried using acetone to soften with mixed results...The guy Brian above hunts through hundreds to find viable ones and also welds the arms to a viable unit to work for a BB distributor...The other guy rebuilds them....
Now I'm thinking about the 2 Hemi vacuum chambers sitting in my garage. Didn't pay a lot but need one for my Satellite.
you never know how good or bad old rubber is. I have the original fuel pump off my '69 r/t and it still works! I don't have any original vacuum advance units that still work.
I have some and a few nos left, depending if the arm goes inward or straight. The straight ones are getting really hard to find for some reason.
Any luck on this ? I just found my can dead on my 383. Points distributor with pertronix ignitor 2... i pulled the can and searched for hours with no luck. Nothing looked the same. Luckily, or so I thought, mine had a factory part number on it and I took it into Napa. Thumbed through their books and found a match, part number crossed to a vc3033. Special order, part came in and the arm does not match ! I don't know what else to do other than order a new distributor....... this sucks for sure
pretty sure points use the straight arm and electronic the offset.
Have you tried AMS obsolete? They have saved me a few times, but be prepared mopar NO$
Is the VC155 that rockauto lists the wrong one
they have good pics
