Orange71SE
I will soon be building a 440 block and want to order this oil pan kit http://www.manciniracing.com/ma8quoilpanp.html problem is that i dont know what pick sptube size to get? Anyone know?
So stock 440 blocks all use a 3/8 pick up? Thats all i needed to know. Thanks3/8" is stock 440. 1/2" is Hemi size. Maybe a racer will tell if you can enlarge the 440 block to 1/2 for more oil?
Would a 6 quart pan seem more suitable for street/strip use?Why such a large pan?
Do you think maybe this will be more suitable for my application? http://www.manciniracing.com/ststheoilpa61.htmlUse a Hemi/six pack style pan. You really don't want a drag racing pan on a street car. Plus and more importantly you don't need it.
Yes you’d probaly be better off with 6-7qt panDo you think maybe this will be more suitable for my application? http://www.manciniracing.com/ststheoilpa61.html
Pro Touring -
PRO TOURING -
STOCK CHASSIS and STEERING
Designed for high horsepower cars that are very low. Cars with big cubic inches, big tires and improved suspension make this pan a necessity.
A stock location sump pan for use in stock Chrysler B & E body chassis. Wide sump increases capacity yet allows ample ground clearance. Fully baffled for competition use. Stock steering will not interfere with this pan.
Pan Capacity is 7 Qts. Plus Filter
5 1/2" Sump Depth
383-440 31580
Oil Pump and Pick-Up Required:
Pickup, 3/8" Pipe Inlet 18328
Pickup, 1/2" Pipe Inlet 18338
Billet Oil Pump, Milodon 21814
Steel Oil Pump, Melling M63HV
Oil Pan Gasket 40700
Oil Pump Shaft (either of these) 21505
21525
Windage Tray 32000
Windage Tray, up to 3/4" Stroker 32006
Dipstick, Billet Stainless Steel 22070
Pan Bolts 85020
Pan Studs 81320
