steve from staten island
- 3:34 PM
- Sep 24, 2012
- staten island,ny
I believe i know what the problem is with the switch and its not the switch. Its the part that rides on the switch which moves as gears are changed. My first question is if the mechanism out side trans are removed can that part be removed and replaced without pulling trans. There is a plastic part that cover the arm and i think its partially broken exposing a sharp edge that gets hung on on ball in neutral safety switch making it impossible to go into drive. Now when the trans is in reverse-no crank, low 1&2 no crank but put it in drive and it cranks. The ball on the end of neutral safety switch is touching the arm and when i put a piece of paper in-between it would not crank. Pull the paper out it cranked. The plastic plunger on switch itself does not move from low, 2 and drive. So can anyone shed any light on this. If they plastic insulator part is sold i still need to remove the arm as its riveted into place. Any help is most apprenticed. Thanks
