Tire and wheel size for 68 Charger
Randy Edwards
1:40 AM
Plain Dealing, LA
does anyone know if a 295/50 15 Goodrich Radial T/A will fit with a 15 x 9 wheel on the back of a 1968 Charger? Will be putting 245/60 15 on the front with 15 x 8 wheels.
Do you have your sizes mixed up? Why a 235 out back and a 245 up front? Either will fit on a 68-70 b body easily.
Easy way to check for clearance place a straight edge on the hub face and measure tonylur first obstruction frame side and fender side. Run a search for “tire size” in the search bar here you’ll see endless threads.
I am running 245's on 15x7 on the front and 295's on 15x10 on the rear of my Charger. Backspacing is key on the rear. Measure for yourself because every car is different, but you will be around 5".
