- 2:53 AM
- Apr 13, 2012
- Granite Bay CA
I have made a deal to buy another 1970 Dodge Charger. This one is an XH model, bench seat, column shift, 383/727 with an 8 1/4" axle. Sometime long ago, it was involved in a collision in a parking lot. The core support was partially removed, the RH side of the core support is tweeked, the inner fender too. The cowl is also pressed back a little.
I should have taken pictures to post, I know!
Out back, I have a front stub from a 1970 Belvedere. It has an unmolested set of frame rails, firewall and cowl, inner fenders and core support. I am considering the possibility of removing the structural members from the donor and welding it into the Charger. I do have welding experience but what concerns me is panel alignment once it is all back together. I have seen the factory diagrams with all of the measurements but the area that concerns me is the following:
Looking at a profile view. what determines the height of the core support? Imagine welding the frame rails and firewall in and having an error even as small as 1/8".....at the core support I could be off by 3/8" or more. What can be done to avoid that? I see some really ambitious builds where guys tear out entire rear structures and somehow end up with everything fitting together again. I know that there has to be some method to ensure proper fitment. It cannot be THAT easy!
I can only guess that you'd test fit the fenders and hood multiple times, take measurements over and over, etc. The body lines would have to be checked and rechecked, maybe even with a construction laser or string line.
What tips can you guys offer here?
Thanks!
Thanks!
