I too noticed some oil film on the coil. I put in that generic coil. It was dry but with flaky paint and a few dents....  it started up, but I could not just leave that ugly coil in there. I had a new Mopar Performance coil in the parts shed so I swapped that one in.
For distance trips, I always bring all the electrical spares: Coil and ballast, TWO spark ECUs, starter relay, even a whole distributor. I have never needed them but they are always in the trunk. This was the first time ever that the car left me stranded. That is a stretch of a statement though, I was only 5 miles from the house and the Wife was there to help in short order.
I do plan to bring it to Van Nuys next month but I am just getting started on the A/C retrofit. I have everything here except the actual water pump. It all hinges on the first step: Getting the car weighed. I am interested in seeing what the car weighs before and after the work. It was a 318 with A/C when new but I never put the stuff back on when I switched to the first 440 in 2002. It still has the stock HVAC box inside and compared to the replacement CCA box, it looks like I'll lose a few lbs there. The compressor and condenser will add weight but the aluminum WP housing saves about 8 lbs. All the back and forth of the parts are still going to result in some weight gain. My bonehead estimate is approx. 20-25 lbs.
The car weighed 3660 with the 318, 904, 8.75 axle and 1975 Dart front disc brakes.
It was 3751 with the iron head 440, 727 and dual exhaust. Since then I have added aluminum heads, frame connectors, torque boxes, bigger wheels and tires. lighter rear disc brakes, lighter seats, sound deadener and a stereo. With all of the back and forth, I am guessing it is under 3900 now. It is raining so I have to wait to weigh it. The guy that installed the windshield a few years ago didn't seal it right and it leaks right over the $1200 gauge cluster I installed 2 years ago. I do not want to risk damaging them. I should just pull the glass and reseal it myself.
