I know, get rid of it,lol. That may happen in the future but for now would like to make it right. Try to keep this as short as possible. This is for my '77 'Doba,12,400 original miles.
Fuel tank redone,sending unit rebuilt,new fuel filter(original one still on car when purchased),carb rebuilt(note stating system should be cleaned because of the debris found in carb),blew out fuel line. Lean burn computer has "remanufactured" on bottom(so replaced at some point,probably when car was fairly new.) Except for plugs, ignition system all original.
My issue.....when car fully warmed up in gear, if you do not feather the gas pedal to start rolling it will die. Almost like it has a miss til you get going(rough feeling). Has a slight stutter on choke but stays running if you hit the pedal. If you hit the pedal too hard and it quits it is a crap shoot if it will re-start, most of the time have to spray some starting fluid. If you just shut the car off by key and not making it quit with the gas pedal it will fire right back up.
No expert here so looking for suggestions. My thoughts lean(no pun intended)to the carb. Accelerator pump not working properly? Float not adjusted properly? If anyone can point me in the right direction would be much appreciated, thanks!
