- 5:13 AM
- Jan 29, 2018
- Midland Ontario, Canada
			I like it except for pulling the switch panel and cluster.
BTW can you share with us your technique to place that upper right nut on the master cylinder mounting stud?
Other than hearing that it's difficult I never really hear how it's done. I actually taped the nut to my fingertip to get it started on the threads.
CHEATER!!!!!!!
Sounds like the correct way, but can't seem to ever get it started that way. I know many b body cars are out there without this nut in place.I used a short 1/2" socket, flex joint and extension. Put the nut in the socket and raise it into position and get it started by turning the extension.
Have you done any lock up test with the brakes? My rear brakes seem well behaved at panic stops below 45mph. Haven't tried higher speeds.
Nice work Mark!
Even with the best intentions to get out in the garage and finish up the welding it seems that the wife, work, kids and grand kids limit my garage time.
I still need a lot more practice time with my welder before I would really feel comfortable with doing the finish welding. For now though I'm just going to blame it on a cheap welder and maybe go buy a new one.
Car looks great. Nice work and good to see it out on the road again.
I sold it the same way that I got it. The guy I got it from never touched it either, backburner on the list of things. Probably hadn't had anything done to it since about 1998.
The 1/4 panels were from around 2005 IIRC.
