A/C Help
bee71
6:25 PM
St. Augustine, FL
Guys,
I have checked all the vacuum pods on our 71 Charger and the switch on the dash and I still can't get the Max A/C to work. What could I be missing as it appears that the outside door doesn't seem to close to get Max A/C ? Thanks.
So the door closes when you apply vacuum to the pod? I'd try vacuum (mighty vac?) at the switch vacuum plug and check if the door closes to make sure the vacuum line is good, and no leaks. Hopefully the switch is good.
Switch is good so were the pods,what are the wires that run to the box to some kind of relay by the pod with the short arm for? Not the blower resistor.
Hope these help, from 1971 FSM:
Let me know if you need more info from the factory service manual.
