Bought NOS door and fender
beebest
12:56 AM
Uniontown, Ohio
Scored NOS fender and door for my road runner at local swap meet yesterday. Got both for 475. Down side, light to some heavy surface rust. Probably will have to be blasted, unless someone has better idea. Let me know what you guys have done.
20180415_185454.jpg 20180415_185357.jpg 20180415_185504.jpg 20180415_185552.jpg
I would not recommend blasting any exterior sheetmetal......Inner frames can be blasted but be careful around the openings so you don't hit the backside of the exterior metal.....
Strip as CNC noted above.....invest in wire wheels and striping disks...
Great score, you got them for a great price!
Thanks, didn't want to go redistrip route as inside door is perfect with factory sound deadener, but better then having them warped and ruined by over aggressive blaster.
Nice score!
Maybe a vat of evaporust?
just curious about the benefit and/or attraction of NOS doors and sheet metal that are beat up and rusty? they are still going to need filler and bodywork anyway?
they actually fit........ that being said, surface pitting sucks
I scored an AMX hood about 15 years ago with surface pitting....... spent some hours with naval jelly and wire wheel..... epoxy primed, stored outside, still looks good today
I have allot of surface rust on a 65 belvedere fender. It was NOS replaced on the cars when it was fairly new. Rest of car is original paint. I was wondering how to remove the rust fairly easy without grinding, scrubbing, etc. Evaporust you have to soak which won't work, but then I ran across this stuff today. $40 bucks a gallon, but it seems to work really fast. I'm thinking of trying out and taking a video or pics to test it out.
Might work for you as well...
Hmm. Ever used NOS fenders?
Usually they don't fit. That's why they were in the parts system.
Chrysler's Replacement body parts were almost always the defective parts that couldn't be used in the assembly line.
Welded together crooked, didn't pass the test, so off to the parts warehouse.
Not wanting to dampen the enthusiasm of the original poster, because NOS parts are a great score regardless, but be aware that you may need to drill some spot welds, and reposition some pieces. And look at the hood adjuster insert. Some NOS fenders have a square nut instead of the round "rosette" shaped insert.
As for the rust removal, don't let anyone near them with a sandblaster. No electric tools either!
Sanding bare by hand or gently with an orbital, a hand spot blaster for pits, and metal prep acid used properly is a safe way to ensure no damage.
I agree, know for a fact as my Dad retired from the old Twinsburg Stamping Plant. Parts that had defects often went to the warehouse verses to the assembly line. Any fender or door NOS or otherwise require some tweaking. NOS usually a little body work to repair that factory ding or dent. I've sanded the fender, used some prep and etch and it actually looks pretty decent now. We'll see how it fits this weekend. LOL Thanks for the great comments, very accurate from my experience.
