67Charger
Combo:
I am thinking the secondary metering plate is adding too much fuel at idle and I have tried to compensate by over-leaning the primary side, causing the lean cruise to be lean even with a fattened main jet. I may need to return the primary IFR to .031 and increase the secondary IAB's more to balance it out some. Once RPMs come up I get tons of fuel from everywhere, which is what caused me to lean out the secondaries. My tail pipe is VERY sooty. The car cruises at constant RPM at 14:1 just fine, but will NOT behave when accelerating at any rate unless in the low 12's and really likes the secondaries open.
- Stock Magnum 5.9
- RPM Airgap Magnum Carb intake.
- QuickFuel Slayer 600 VS Carb
- Mains: from 68 to 70's
- Secondaries: from 73's to 71's
- PV: 6.5
- Pump Cam: from Pink, hole1 to Orange, hole 1
- Pump adjustment: seems to have a TINY lag. may need more preload
- Squirter: 31
- IFR: from .031 to .028
- IAB: Primary from 78 to 84, Secondary from 37 to 43
- Idle screws: 3/8 turns out
- Transfer slot: "square" visible from underneath when primaries are closed
- Idle AFR in gear: 12:1
- Screws will kill it if both in, but seem to have little actual effect on A/F beyond 3/8 open. Cannot get AF to 13+ at idle
- Cruise (maybe 10% throttle at 60 mph w/ 2.76's, 2000 rpm): 14:1
- Very gentle acceleration, 15 - 16:1, surging, missing
- Moderate accel: Lean spike (18:1 +) on tip-in, hesitation, sustained bog, then wakes up once the secondaries open.
- Accel hard enough to engage PV: 12:1, but not happy until secondaries open
- WOT: from idle will bog terrible, 10.8:1 - 12:1 after the secondaries open. It feels good past about 3000, but would probably be better if I could get it closer to 12.5 or 12.8.
