pwDave
Ok, so I am making an up-grade to the oiling system on the old Plymouth, super stock rear sump pan w/dual line pick-up, the drag link goes thru the pan on this one. a problem has arisen, both tie rods popped loose with-out much fuss, and the pitman arm, the idler arm on the other hand is wanting to be stubbern and not come out, the taper is down in the hole of the drag link so far that the puller will not go on it, I've tapped on it with a small beater with out any results, and past this point with out being able to use the puller I'm on the way to the smoke wrench. anyone else run into this or simular and have a simpler or better solution?? I would be willing to bet its some chinee piece of crap that just slipped in there, if I try some heat on it, it shouldn't take much should it? Dave.
