New Coil, New Ballast Resistor, No Spark?
Hankohop
9:56 PM
Pittston twp
I am currently working with a 383 with a spark issue. The coil was just replaced along with the ballast resistor. Currently, the car has a Proform electronic distributor in it. the coil checks out for resistance and with a test light it shows that power is being sent to the distributor. I'm thinking there's either a problem with the ignition module or the distributor but i'm not quite sure how to check them out. any advice?
Ground for ignition box good ? I'd swap ignition boxes, they're cheap at napa... had a few leave me stuck, fortunately all at the house !
Are you getting spark out of the coil to the distributor?
Is there a way to test the ignition module? And what' the best way to test for spark at the coil? Thanks guys
Use your test light to coil connec9. Try starting engine. No flash at light no juice to coil primary.
Ok, so i probed it with the key in the on position. the test light lit up and when cranking it didn't flash just stayed on continuously. Am I in good shape here?
Sounds like you were checking coil positive with test light to ground. If so, then all good there. Is that dist a stand alone unit ? If so, you need to check power to it also.
Whats grounding the coil primary circuit so the secondary energizes? Sending high voltage to the distributor cap? No break in light at coil primary negative post, no energizing coil secondary.
glad you said that but mad at myself for being a dumby. As i checked out the wiring on the module I decided to double check my connections. Turns out i had a bad connection leading to the ballast resistor. rep-spliced it and boom! I've got spark. Goes to show that you can never ignore simple solutions! thank you everyone for your help and input!
More likely than not, it's always something simple. Glad to hear you got it figured out quickly.
